SWE1 Error code
Mrmb123
Jax, Florida
My SWE1 has keeps saying that my coin door isn't closed, I checked the switch and it isn't in the switch but now I also see an error 1/25c 4/1G. Any place I can find what the error code is to fix this issue?
Well, 1/25c 4/1g sound like coin settings, like 1 game for 25 cents and 4 for a dollar or something.
Considering that you had a "coin door not closed" error, and the switch is registering good (and the coin door was closed), I'd first check the grounds to all the coin door-related switches, then check J113 (coin door closed switch) and J114 (coin switches) for proper seating, loose wires, or cold solder joints.
Does your test report give you any other errors? Any blown fuses?
Yeah I checked the manual for the message already. I will check J113 and J114 tonight and double check the fuses. No other messages or errors, I was thinking it might be a ground issue and probably should have just started looking for those switches but wasn't sure if the error was trying to tell me something else.
