First of all let me just say that I am not that familiar with arcade monitors and picture tubes. I have a cabinet with a 19" monitor in it that I would like to remove and replace with one from a 20" RCA XL100 TV. I would think that the 20" would fit in place of the 19". Am I correct on this? Second, is there going to be any difficulty in swapping them out, or will a TV monitor not give you the same look as a standard arcade monitor? Do I need to keep the current monitor and just use the 20" picture tube? I plan on making the cabinet into a 60-1, so I will be adding a new jamma harness and board. Will the jamma harness hook directly up to the tv monitor or do I need some type of adapter?
