Swapping tubes?
mneubey
Donor 2024
Hi there, I've never attempted it, and wanted to see if it is at all feasible for my situation ...
I have a working WG13k7886 chassis on a broken Orion M34JRW23X09 tube
and a non working WG13k4706 chassis on an in tact Toshiba 3T0DJB22 tube
Is there any way at all I could swap the k7886 chassis over to the tube that the k4706 currently resides on without completely screwing something up (or putting myself in any danger?)
Not really sure what the rules are for this. Any advice would be greatly appreciated :)
i do not think so.
the WG13k7886 uses a cr23 pinout on the neck
the WG13k4706 uses a cr24 pinout on the neck i do believe.
which would make them incompatible.
Peace
Buffett
Go here: http://ieure.github.com/monitors/
Type in the first tube model. Click the row when it comes up, and it will switch into compatibility filter mode. Start typing the second tube model. If it's compatible, it'll be in the list.
that is a great page glad you told us about it . thanks
Thanks so much for the info everyone. That link is killer, thanks for that as well!
