Swap non-working WG U5000 for WG 27K7391?
I was looking at the pictures I have of this, and noticed the following locations are not populated. The guy I got it from said the monitor was working, and I did infact play a game on it prior, so I don't think they are necessary.
C729, C120
C105, C616 and C110 have a white substance below them it appears.
And as pointed out before, R111 appears cracked.
So I am guessing that even though this was capped at some point, I will probably need to do it again, at least with the ones that appear to be leaking.
the white stuff is glue to hold the larger caps to the pcb so they don't tip while going through the wave soldering table. if you caps are glued down still then they all weren't changed and you should recap it with good quality caps and not those crappy VZ caps it has now. we have the kits if you need with the best quality caps.
Thanks, I will probably end up purchasing a kit of two (might get a spare chassis just in case.)
As far as the other parts go, does anyone have a list of the components so i can look up what resistors I need?
Just ordered a cap kit, filter cap, and HOTs for this. Need to figure out what value the R111 resistor is so I can get that ordered too.
470 ohm 1 watt metal oxide resistor. i just sent you a link to the one on our site.
