Swap 19" and 25" K7000 boards?
syplex
Portland, Oregon
I have two Wells Gardner boards, a 19K7901 and a 25K7193. Can I hook the 25" board up to a 19" monitor? What about vice-versa? Can I swap the neck boards as well?
I want to test my 25" board on my 19" tube without swapping yokes to see if the 19" tube is still good and to also figure out where my missing blue problem is (on the 25" cab). I know these boards are very similar but the 25" one has bigger heatsinks and different components and a higher B+. If I can swap the 19" board onto the 25" tube I would imagine I shouldn't run it very long because it would be underpowered?
No. The 19" K7000 tube will have 8-pins, and the 25" K7000 tube will have 10-pins.,,,
There are a few 10 pin K7000 19"chassis but I have only seen a couple in my travels. They have a noticeably larger neck but I still wouldn't do the swap. At least I think they are 10 pin. I don't have any here to look at to confirm.
So what can be swapped, just different K7000 boards all for the same size tube?
Sometimes. There are also medium-resolution versions of the K7000 to watch out for also, and they use a different yoke....
