SW High Score Resetting
FrizzleFried
NAMPA, Idaho
My SW high score is resetting after a couple of days.
What chip am I supposed to look at replacing? Where is it located? Where may I find one? Finally... if I picked up a SW/ESB kit will that take care of the issue that way?
Thanks... unfortunately arcadechips.com has a $15.00 minimum order that they don't mention until you register there...
Hi,
Yes we have to have a $15 min order at our site, with the value of the dollar these days and the time and massive cost it takes to stock the parts.
Let me know if you need anything,
Mark Capps
If you install the Vector Labs SW/ESB kit you remove the old X2212 as it's no longer used. All game settings and Hi scores are saved by the new kit plus you can play Empire Strikes Back :D
It might very well be a cap problem. If the voltage isn't right, I found the 2212 will not function right and you will lose settings. You might want to try replacing C94.
... Altan
