Supertechnoboy's Joust Cocktail De-conversion/Restoration
Rather than painting the coin door bolt heads, I decided to re-do the black oxide coating. This creates a "light black" matte finish, if there is such a thing. Here's what I started with. (The one with the tape is not original, and had to be cut to length.)
After cutting the one replacement bolt, I needed to remove the letters on the head. I added a nut and ran it against abrasive with a drill. First 120 grit, then a sanding block to smooth it out.
Then I removed the head finish from the rest of the bolts with a wire wheel.
Now I mixed up the black oxide concentrate with water and dropped the bolts in for 6 minutes.
I used the cotton swab to stir and get bubbles off.
Afterward, rinse with water.
Then coat with penetrating oil and rub clean.
And... PRESTO! Black bolts.
Interesting! I hadn't known about a product that can blacken old bolts. I need to try it out.
I'm assuming this is a similar one on Amazon:
Thanks for the tip!
Del
It looks good!
To me, the one that seems closer is the Wilsonart Montana Walnut. I was just looking at it today with their online sample in Illustrator today. I'm not sure if I should pull the trigger or not. I won't be replacing the inside panels and the outside panels aren't really needing it; with the exception of some gouges. The top laminate is damaged though, especially the top pieces. It has almost fallen off.
I'll insert it here to show what I was looking at.
It looks good!
Wilsonart will send you free samples. I ordered several different walnuts, but Montana wasn't one I tried. They look a little different in real life than online.
I'm not doing the inside panels either, since it would require breaking down the whole cabinet. In my photo from the last post, you can see a little of the inside panel with the original laminate vs. the new on the outside. If you decide to only do the top and want some Walnut Heights, I have more than enough that you can have for free.
Happy Independence Day! (If you're in the USA.)
I put my big-ass, old, color laser to work on some labels. These are PDFs from Pinball Rebel, printed on Avery vinyl film labels (except A707 inside the back door, which is cardstock).
And I shot some black on the underside of the control panels. I'll lay it on its back when I finish the front to prevent runs.
Time for the coin battery mod I see.
I actually had an old NVRAM for Joust in my parts pile. I think I bought it new from Arcadeshop many years ago. I socketed the chip location and popped it in, and it works!
After reinstalling the lower coin door, it wouldn't close completely. I had to perform the "lilypad maneuver" for clearance, and now it works great. Thanks @lilypad19 for showing us the way.
Took a little time off and went fishing in Alaska. I've got lots of salmon now.
I borrowed a lathe at work and turned down the sticks, using an old Defender cocktail stick for a prototype. This wasn't my most beautiful machine work, but the sticks fit and they'll work great.
With the sticks finished, I could FINALLY complete the control panels. I'm pleased with these.
I also glued and routed new laminate on the top.
On every cocktail I've seen, the laminate is chipped on the sharp pointy corners near the control panels. I applied wood hardener to the pressed wood below the points, and built up the corner a little with bondo. Maybe it will help.
Done! I'm getting a new glass cut at a local shop, which I'll hopefully have this week.
Got my glass back today, and it looks great and fits, too. You can see why I needed a new one. What appear to be scratches in the top glass are actually just showing through from the old one on the bottom. This is 3/16" grey glass, cut and tempered, using my old glass as the pattern. Cost was roughly $150.
