Thelastone
- Joined
- May 31, 2024
- Messages
- 3
- Reaction score
- 0
I have an orange and blue Skeeball Super shots that will not fully boot. The red light on the main board blinks consistently when power is applied but nothing appears on the display. The problem appears to be in the main board. If I swap in a known good board it fully boots without issue. Voltages are within range of the manual specs (+5.2, 12.1,-4.9). I checked diodes, resistors and capacitors and all seem normal. I also swapped the main program eprom (no change). One oddity is while the board is in this state it still recognizes when I hit the jackpot reset switch (green led on bottom of the board lights up. Hoping someone has a working knowledge of this board and can lend me some knowledge before I have to send it off to skeeball ($$$).
