Super Qix - Player select problem
pinbotler
Winnipeg, Manitoba, Canada
Hey all hoping someone can give me some info. Have an original TAito Superqix board in a converted Pac cocktail. I cannot select a player with this pcb. Coin up one and I cannot select one player start. Add a second credit and 2 player game automatically starts. Stuck my other jamma board in and player select works as it should.
My question is is there a section to a jamma board (or this one) that works only with player start/select? Or is this most likely a rom problem. I am leaning away from roms as I have seen no other issues, even when i change dip switches or run test mode. Can get pics in the next day or two if that would help, just looking for some guidance.
For the record: reseated all the roms, cleaned all the contacts, and swapped out jamma boards to make sure it was a pcb issue thanks in advance.
