Super Pacman woes...
darthphunk
Scio, Oregon
I've been piecing together a super pacman for over a year now. I finally have all of the parts to make a working game... and I can't get it to work.
When I picked up the cab, someone converted it to a Gunsmoke. Whoever converted it was nice enough to leave everything inside fairly intact. Still has all the power guts. Harness was a little too hacked up for my tastes, so I put a new one in there.
After installing everything... nothing. Monitor powers up, the board does not boot up.
I tested the power from the Power supply and I am getting +5 and +12 dead on.
Harness looks fine. I checked and I am getting the same voltages on the PCB side of the harness.
I took the board to a friend who has a super pac, and popped it in his cab, and it came right up.
Any advice?
This may be a pain, but I'd recheck the harness. Find a schematic and be sure you're getting voltages as well as grounds on all your connections. If you really want to be anal, you can do a continuity test on every wire to be sure you have a connection on each end. Those have failed me as once I had a intermittent connection on a ribbon cable that a continuity test failed to find.
look at the schematics and verify every pin/connector and wire
you know it works so, somethings off/bass ackwards somewhere
WELP
I've been working off of the schematic and once I realized "-SENSE" was the -5v line... I'm getting zip on my meter from there, and the -5v adjustment pot on the MCR board does nothing.
That's gotta be my problem.
Sounds like it probably is. I replaced the power supply in my Super cocktail a while ago. I used a computer PS but I don't remember hooking up the -5V. I guess I must have had to, otherwise it probably wouldn't work. I haven't opened it up in a long time. When you get yours running, post some before and after pics. I still consider a Super Pac upright to be my #1 grail.
I had a spare switcher laying around so I popped that in there.
Worked great!
For about 30 seconds and then the switcher started pouring out smoke. Board looks fine, I double checked my wiring and I didn't goof up anything. I just ordered the Arcadeshop kit and I'll fix my harness and throw that in there.
Woohoo! Can't wait to get this in the basement barcade...
