Super Pac-Man cocktail table powers up, no audio & no video
Jake13
Donor 2012
Solvay, New York
Hi,
I have a Super Pac-Man cocktail table that powers up & the monitor works, but I have no sound and no video coming from the board. Any suggestions or theories are appreciated.
Thank you!
Check the continuity across the fuse with the multimeter. A fuse can be blown but appear to be ok visually.
By the way, has the game workied while in your possession, or did you buy it in non working order?
Is there a power brick in there, or has it been changed to a switching power supply? Is the harness connected well at the board? Have you removed the wiring harness from the board and then reattached it? It is not uncommon for the edge connectors to deteriorate. Oftentimes they can be rebuilt if they are toasty.
Thank you!
I just bought it from a reputable source and it was working recently.
Everything is original inside.
I did find a fuse that appeared in tact, but was actually burnt; hopefully that was it!
Thanks again!
