Super Off Road Track Pack Coinup Question
nanoryan
Washington
Hey guys,
I have a Super Off Road that I just put a Track Pack board set into. The game displays fine but it asks me to push the Join/Credit button after I coin up and I can't figure out what button it's talking about. With regular Super Off Road I just hit the nitro button to start the game but that doesn't work with the Track Pack.
Anny suggestions for how I can start the game? Do I have to wire up more buttons?
It should be the same button. At least our off road was. I suppose there might be a setting to change, or a wire to move if your going from a board setup for 2 wheels to 3 but I don't think there was.
I have a 2 player with the track pack all i do is press the player 1 or player 2 button to start after coining up(two player has two nitro buttons and 1 player button per player not sure on a 3 player setup)
You buy that from Cincinnati?
When I did the upgrade, there were 2 extra chips blocking the upgrade, a serial EEPROM and a security chip. Below is information on what needs to be swapped.
The Track Pak upgrade is a 26 chip swap.
24 eproms, 1 serial EEPROM and 1 security PAL chip
Eproms:
Top Board (16 chips) : U2,3,4,5,6,7,8,13,14,15,25,26,27,56,58,59
Bottom Board (8 chips) : U3,67,69,90,92,93,94,95
The Serial EEprom is an 8-pin 16x64=1024 bit NMC9346 located at U120bottom
The security chip is a PAL16L8 located at U85bottom.
(...this is problem blocking the upgrade...)
