Super Off Road, Resolution?
ArcadEd
Tucson, Arizona
So I pulled my Off Road board out of the cabinet (running 25" K7000) and hooked it up to my test bench (running 19" 4900) and I can't get a good picture (see attached).
at first I thought it was the harness I made, so I pulled the one out of the cabinet and used it, with the same results. It's almost as if the monitor can't pick up the correct resolution, but everything says super off road is standard resolution.
I have the RGB hooked up and the Ground and Negative Horizontal and Vertical syncs to the right place, I have checked them 10 times each just to make sure.
The monitor works fine when I plug in my Jamma harness and games.
I would love any help. Thanks.
It's standard resolution... did you try adjusting the H Hold/Freq pot?
DogP
Wow, I am a moron :). I messed with the vertical hold but didn't even notice a horizontal hold.
That did it, thanks.
Ed
