Super Off Road - pin missing from Molex connector
alexhertz
Donor 4 years: 2021-2024
Trying to get my Super Off Road working. Generally in good shape and made a few fixes but I am not a connector expert at all. I learned to solder (poorly) last week, no joke. On the back of the blue wheel is a circuit board that the harness plugs into. The harness is a Molex 2574. It seems to be a 6 circuit version of this: https://www.greatplainselectronics.com/Datasheets/connectors/Molex/SD-2574.pdf
Added some pics below. Looks like I am missing the fourth tin pin (farthest right).
  • Can this be repaired?
  • What pin (crimp tin) do I need? (that's the big question)?
  • Is there a tool to de-pin the 2574 connector?
  • Is there a crimp tool needed to crimp the pin to the wire?
  • Is there a tool to re-pin the 2574 connector?
Any advice would be appreciated!
here is what i have left in stock.
you can use the AMP version which we stock too if you want to replace the entire housing.
the tool would be this to remove the pins
Thanks! Ordered the parts and some spares. Super appreciate it!
