Super Off Road Owners, Please Help!
Ghostnuke
Lawrence, Kansas
I just picked up a Super Off Road project cabinet. It is supposedly working, and has all of the parts except the one circled below. Can any of you guys help me out with better pictures?
Would it be best to try to find the original power block from a cabinet, or can I just throw in a switcher and an ISO? Are there other parts involved? Any help you guys can provide would be appreciated!
You should be fine just wiring up an ISO and a Power Supply, it looks like there's also a line filter there. So you've probably got the main power line running in into the line filter, then out the other side. Then you've got the ground and common wire running over to the iso, then splitting off and also going to the power supply. The hot would run through two fuses (split) one for the main line and one for just the line going to the ISO.
I had one of these a while back, there was a problem where the pots on the pedals didn't ground properly, so I had to run the 5v and ground wires from the pots straight to the power supply, instead of through the pcb.
good luck!
