I had acquired the Super Bug Cab. I had inspect everything and do not see why CP is not working.
This is only board attached to the Super Bug.
I had noticed there is anohter connector on other side. Am I supposed to use it?
I had checked the harness and everything is attached proper and it fires up just fine. Game runs perfectly. I was not able to use coin op nor CP.
I needed the connector map for super bug so i can see which lines goes to.. I had printed out the stack of paper via library here in KLOV and its pretty complicated so maybe someone has trick to it.
Thanks in advance.
Thanks in advance.
