Black Matrix
I have been running down a dead knocker (unsuccessfully). I believe everything is working. So I thought I would replace the edge connector pin at pin 6 of the pcb. Thats the one that grounds the return voltage of the coil. But after I cut the wire and tried to replace it with the ones I got from bob roberts, I found its a different size or it just won't fit. So my question is, does anyone know what size of pin and where I can find replacements for the factory original size. I can say it is an amp connector 30/60 two row edge connector. Didn't see them in bob roberts parts list. Any advice as to what to do. Emailed Steve young on a complete kit and he said I should try bob roberts. So it sounds like he doesn't have the edge connector. Let me know if you have any thoughts on it. Thanks.
