I know this is going to make some of you say "MORON", but I'd like an answer anyway.
I know when taking a midway Ms. Pacman PCB and running it in cocktail mode, the pin on the harness has to be "grounded". But is this as simple as stated, you take a wire, solder it to the pin on the harness, then splice this wire into the other ground wires?
What the easiest way to test this prior to soldering? Can I simply touch a ground wire to the cocktail pin?
Thanks.
Thanks.
