#32
Is it OK to turn off a juke mid-record? Will it cause damage to the record in the long run? If there is a ton of selections to go, is it better to reject each then turn off or can I just turn off? I noticed when I do just turn off, all my prior selections are still stored when I turn it back on (though it does reject the record that was playing when the machine was turned off).
#33
Record reject... does IT damage records? It almost sounds as if the record is being played backwards for a brief 1/2 second or so before it actually gets pulled back in to the cradle...
#33
