Stripped Screw!!
skere26
PITTSBURGH, Pennsylvania
In attempting to exchange the shot LM323k regulator on my ICB board, the flathead screw refuses to come out. The nut on the back just spins and a wrench to steady that only causes the soft screw to strip. How the F am I going to get this out!
i like the Dremel idea. Normally i would just drill it, but that damn headsink is in the way, and ice cold beer boards don't grow on trees :). TO HOME DEPOT!
or just dremel the groove a little deeper with a cutting wheel. It might give your flathead more bite. Worse case is you dremel too far and take the head off and the screw falls out anyways.
Vampliers. I always have a pair of them handy. Work great for things like this. Nice tool to keep on hand. I highly recommend them.
Sans that, use a Dremel wheel as others have suggested to cut a slot in the screw and back it out with a slotted screwdriver.
this normally works well for me, if not then to the vicegrip/drill option.
