Street fighter plays blind with a line
sohchx
frederick, Maryland
I get full sound and play but I have this line across the center of the screen which you can see has animation movement in it. I tested the board out in another cab and it plays fine so it's not that. Any suggestions?? Thanks
ha mine did the same but had a vertical line
If you have just a vertical line you should shut it down immediately. This usually means your gonna blow something more expensive than a cap.
OP---start with a cap kit. You may end up replacing the VOT.
