Pretty sure he realises that
Sup Hewitosn. Good to see ya again bud.
i had a good feeling that it was the c board, i tested the a board when i swapped it out with my megaman the pb board and same thing. the guy said it all worked when he shipped it, and it seems that the c board was the only thing that got damaged, if i could find one of those i would be in good shape.
Did you try swapping just the bottom boards with you W.W. board? In general, bottom boards are pretty much universal. It's the tops boars that are not. If you didn't, then try just swapping bottom boards first. And see if that works.
If that does not work, then try a working W.W. "C" board.
Best Case: Find another 90632-C-1 W.W. "C" board with the same part numbers on top of the Big Black graphics chip and on top of the little, socketted PROM chip as your W.W. "C" board. And test the board with it. If it works fine, the swap the part.
Next Best Case: Find another 90632-C-1 W.W. "C" board with a different part number on top of the Big Black graphics chip and the same part number on top of the little, socketted PROM chip. And test the board with it. If it works fine, the swap the part.
If you're comfortable with re-seating chips, you can swap the little PRom chips around--if you feel the need.
"C" Board Part # 90632-C-1:
With Big Black Graphics Chip #: CPS-B-17, CPS-B-15, CPS-B-14, CPS-B-12, CPS-B-05 & Prom Chip: C632, or
With Big Black Graphics Chip #: CPS-B-18 & Prom Chip: 632B
