Street Fighter 2 Fuse Question
Walkamo
Garden Grove, California
Hi Everyone,
I recently purchased a Street Fighter 2 Pinball machine and am having difficulty getting the lower left flipper to work. When I bought it the flipper was stuck up, so I assumed the coil was bad. I purchased a new coil, replaced it and nothing..
I noticed on the bottom of the playfield a list of fuses that the machine uses and the lower left flipper does have it's own fuse, however I don't know where the fuse is located. I do see a bank of fuses with F1 - F25 labeling, however they don't say what they are used for. F25 was blown and had the wrong fuse installed (Not sure of the value, however looks like all of the fuses are supposed to be Slow Blow and this one was not)...
Anyone here have this machine or a copy of the owner's manual?
Thanks,
Chris
street fighter 2 pin
yes i have both
under the playfield everything is not writen there a hole bunch of Fuse spots on this machine you really can'nt miss them.
Are you talking about the Flipper for the Car Cruncher?
yes i have both
I am talking about the lower left main flipper. All of the other flippers work.. I just think that there are some wrong fuses in this machine... I was hoping find a list of the correct fuses for each area so that I can check them and replace if necessary..
Thanks,
Chris
Could be a couple of things. Get a multimeter and check voltage for the coil. Might also want to put it in test mode and check all the coils.
