I have two Williams power supply boards that are acting the same way. These are the newere Joust & later style with teh separate heat sink.
When it is plugged in without the output power cable (i.e. no load) the +5V is right on. When the CPU & ROM boards are plugged in (i.e. under load) the +5V goes to 1.26V. So far I have
1) replaced all the capacitors in the 5 Volt section including C10 (the 18,000uF)
2) I have replaced BR1
3) I made sure all the fuses were the correct size and that they have continuity.
4) I replaced IC2 (the 5 V voltage regulator
5) Pulled Q1 (the SCR) and replaced it
6) Reflowed all the headers
7) Cleaned the corrosion out of the fuse holders
8) Run a diode test on D2 & D3
9) Swapped a different set of outboard power transistors (the ones on the big heat sink)
Before I just start shotgunning parts (even more than I already have) has anybody ever seen this before & what did you do to fix it?
Thanks,
ken
EDIT: Yes I have tried a different PS board and everything works with the other board.
Thanks,
ken
