strange interference on daytona usa le [solved! new problem tho]
hey guys, i have a question for you. i have a daytona usa limited edition single cab. these units shipped with a k7500 as opposed to the standard nanaos. for some reason, there's interference in the monitor as what I believe is called herringbone altho i could be wrong. so far ive tried adding an additional ground between the pcb and the monitor, removing a ground (incase some wires somewhere were too close together), and disconnecting the sound amp incase the speakers were causing the interference all to no avail. the only thing i havent tried is disconnecting the marquee light which im about to do in a minute.
i saw kens post about jumpering the two grounds together but it uses a computer-style psu that i can't do that on. it's a happ psu so it can't be that old, voltage reads 5.10 on the button.
what else can I do to get rid of this interference? its not on any of my other machines and moving it around doesnt help.
