Waterborn
So I am not sure where to go next. I recapped and installed a new flyback in this monitor and was still not getting anything. After messing with it alot, I put it aside and went to work on other projects. Well today I pulled it back out and decided to see if I could figure out what was up. Noticed one of the fuses was shot, so replaced that and reflowed solder to the power feed to the neck board as the connection looked a bit iffy. Put power to it and now I can hear the tube charge up and it gives a good pop when discharged, but still I get no neck glow and absolutely no picture/anything on the screen. I feel as if there is something amiss with the power going to the neck board, but can't figure this out. Anyone have any ideas on what I should check next. I would really like to get this monitor up and running as the tube has zero burn it.
Thanks,
Dane
Thanks,
Dane
