dieseldogpi
I have a Williams Flash and the upper right flipper has been having a problem. When the button is engaged, the lower flipper works perfectly, then the other flipper slowly moves until its locked. Its not physically getting held up anywhere. It moves just as freely as the lower flippers. I changed the coil, still a same problem. What should the voltages be at the lugs of the coil?
