Sticker Residue Remover Safe For Artwork?
jow
California
This is bugging the crap out of me:
Will goo gone get that off? Any other remover I can use and not worry about the artwork? My OCD is going crazy right now. I have to get that off!
there is a 3M product we use and works great. We get it from a Auto Body supply company here. Call me Tuesday and I will give you the name and number to order. 1-423-322-4213
Kirby's Lickity Split with a Magic Eraser, I just used that for the same thing on my Omega Race cockpit last night, worked like a charm. The trick is to go easy and make sure you're not saturating the area, using gentle scrubs. Then wipe down immediately after using.
i'd start with isopropol alcohold. i start all my cleaning projects with it ;-)
i like Goo Gone (the orange/citrus based stuff) for cleaning adhesive residue off of plastics. it doesn't cause haze or pit the surface like some of the harsher chemicals can. because it's not particularly harsh it can take some time for it to work but i've rarely not had it do a great job if i let it soak for a bit.
whatever you do, do NOT use Goof Off as it will damage the plastic.
