Stern mteror issues.
89pin
Wayne, New Jersey
I have a 1978 stern meteor. Played it with friends just fine, powered it off and unplugged all the machines. let it sit for a week, powered it on and lights go on and thats it. Green LED on pc board is not on. I would assume the board is not getting power. (board is not old.) Any help would be appreciated. Thank you, Jason.
Current pins.
69 Chicago coin Action, 71 Williams Solids N Stripes, 78 Stern Meteor, 75 Williams Big Ben.
Current pins.
i could be wrong but i think this machine may be plagued with the same board interconnect issues as the likes of black knight possibly, in any case google pin repair to pull pul up marvins site, you need it!
Check all the fuses first. Then unplug and replug the connectors at the Power Driver Board in the cabinet.
Do you have a multi-meter? If so, test the voltage on the test points on the Power driver board. Red on the TP and Black on the GND. If they all are within specs, check the voltage at the test points on the MPU and Solenoid Driver Boards. Try to find where it is not getting power.
