Stern Harley Davidson Question
gsrogers
Donor 2023-2024
Friendswood, Texas
Just picked up a Stern 2nd edition Harley Davidson...home use only. But it sometimes goes into a flashing mode and I can hear a solenoid firing....like it has lost a ball or something. The display goes blank during this mode and I cannot go into the diagnostic mode. Is this some kind of Stern thing? Anyone have thoughts? Thanks
Little update...when I turn it on it boots up then goes right in the flashing lights with no display. thoughts?
Does it just keep flashing like that until you restart it? What happens if you put coins in or try and start a game. I know that my Baywatch had the DMD go out sometimes while playing and it was a cold solder joint on one of the header pins that was also the culprit. Could also be a low voltage issue where there is not enough juice to power the DMD.
It will just keep blinking with no display. It also does not respond to any coin up or diagnostic buttons. It is like some sort of "failsafe" mode....
Garry
