FS Parts: Stern Frenzy pcbs, complete harness , etc $300
redfivexw
Donor 6 years: 2017, 2021-2025
Massachusetts
I am cleaning up around the shop. Time to move some of this stuff along. I removed this complete outfit a few years back from a damaged cabinet. This is everything inside the cabinet from the wall plug to all the boards and all the harnesses etc. This everything you would need to completely bring back a frenzy. The boards were working at the time of removal. $300 plus shipping .
do you know what the difference is between these boards and those for a berzerk?
is most of it the same, maybe a few rom chips need to be swapped?
does this have the control panel harness for the original batstick or did Frenzy even use it?
thanks
thanks
I believe the zpu is different, but I cannot answer with certainty to what you need to convert. This game had a Wico leaf.
thanks
The only difference between berzerk and frenzy if the zpu (rom board)
Berzerk is zpu 1000
Frenzy is zpu 1001
You can swap between the two in the same cabinet and have both games.
The memory map is slightly different between Berzerk and Frenzy, so it's not a ROM swap.
I should dig out and retest the rest of the ZZPU Berzerk / Frenzy multigame boards one of these days...
