Stern Freefall Wiring Harness
coolwhs
Dyer, Indiana
I could use a Stern Freefall wiring harness, the one I have has been hacked up too much.
If you have one, let me know.
A previous owner removed the wiring to J1 completely (transformer connectors partially melted), J3 has 1, 2, 6, 9, 10 cut. The wiring that's been removed isn't laying in the cabinet, and even what's left has bare areas in random spots presumably caused by the heat; so I'm looking for the whole harness just to be safe. Somehow the game still works.
Unfortunately the missing wiring isn't there at all, and the wiring currently there is bad shape. I'll need the new connectors, but I'll need to rewire it completely.
If the game works, GI and insert lighting works, I'm trying to understand how it can do this with missing wiring? Do you have a manual? Not trying to bust your chops, but can you post a good picture of the wiring at the rectifier board?
Just asking because they did not make many of these and a harness in good shape is hard to find.
Not a problem, I appreciate the help. I've attached some photos which are a little small due to the maximum size restrictions. On the #2 score there is some electrical tape covering bare spots in the wiring and various other areas have bare spots too.
As hacked up and burned as that rectifier board looks, I would buy a new one. I've seen 2 versions: one where you have to solder the transformer wires to, the other you crimp on a connector and it plugs into the board.
Yes, replacing the rectifier board was also top on the list, although it looks like it'll be a little harder to find a harness than I was expecting.
