Stern BDK ramp
Mj1234
New Jersey
I'm trying to replace the ramp on my BDK.
Anyone know what the 2 silver things are above the screws?
It isn't solder, and I feel something underneath
Anyone know the best way to remove?
Thanks!!
By 'ramp', do you mean the spring metal flap at the *entrance* to the ramp? Above the two screws holding that area of the ramp down are two rivets - but you'd need to remove the entire ramp entrance assembly and then drill out those rivets in order to remove/replace that spring steel flap.
No need to mess with those rivets if you're just trying to pull the *entire* ramp assembly (entry, wireframe, etc.) otherwise.
Yep I mean the spring metal flap.
I guess the rivets what was I was referring to
I couldn't quite see how they were held down, but I guess I'll need to remove the ramp assembly to drill them out so I can replace the spring metal flip with one with no wear on it
Thanks a ton for your help
