Stern Arcade Harness Pinnot? Time Pilot 84 same as scramble?
simpsons99
Snohomish Washington
Someone sent me a Pm saying they had a Time Pilot 84 Harness for sale . Told me too look and see if it was the same pinout as the scramble i'm needing.
It's got to be the same cable from the cp plugs right into the Harness.
Please help guys!
I would love too get this running Scramble!
Please help guys!
Yes... same thing. Konami vertical pinout.
are you sure? I've been told that Super cobra is the same as scramble? Then some says no it's different
the PCB pinout should be identical between Scramble, SC, and TP '84, but it's possible the harness on the power supply side or elsewhere is different.
either way, it shouldn't be hard to wire up the new harness to work with whatever power supply you are using.
