Stepper Motor Substitution
uriahsky
Lompoc, California
I want to find a Cheaper replacement Stepper Motor then what the manufacture wants to sell me. It is being used in a redemption game called Slam A Winner and it drives a platter around in a CC direction all day long. They use the stepper to determine what hole the ball had fallen through. The motor that is in it is a AstroSyn 23LY-C205-03V They want 128.00 for a replacement motor.
I think this is the same spec'd motor that is used in Claim Jumper and some other Benchmark games.
My question is what specs on a stepper motor have to be matched exactly and what specs can just be close?
I know you have to get the degree correct. This one is a .9 degree and it is a Hybrid that is using only four of the six wires.
But what about the
Resistance
Current
Inductance
Torque
etc...
The Astrosyn has the following:
Model Number 23LY-C205
Voltage 4.0volts
Current 1.10 amps
Resistance 3.6ohm
Holding Torque 3000
Inductance 5.3mH
Rotor Inertia 55.0 g-cm2
Detent Torque 250 g-cm
Weight 360 grams
I know what a lot of you are thinking, it depends on the controller? Unfortuantly I think it is a custom controller and I don't have any info on it. It can't be replaced with a generic one, I am pretty sure of that.
But there has to be some general guidelines I can follow??
I have searched for answers to this question but could not really find anything. Perhaps I worded the search wrong.
Anyone help me with this?
Thanks very much,
Russ
Stepper Motor Specs
Found a set of decoder charts for AstroSyn model numbers @ theprojectasylum.com/electronicsprojects/componentdata/minebeasteppedatacirca1999.html
Good luck!
