GunSmoke Guy
Step by Step Pac/Ms.-Man Original Power to Switching Power Supply Kit
What exactly is involved with removing existing original power block, do you need to discharge anything ? While converting it into a newer switching power supply kit as seen in this photo: What exactly do you gain, or lose (besides originality) by doing the conversion in your opinion. Does this particular kit also require you to get a jamma adaptor or can you use one in addition to the kit so you can play JAMMA games ? It claims simply plug and play. Do you need to splice anything etc.. Where do those blue connections plug into inside the existing original cab. Any one have pics utilizing this particular / similar kit ?
