Check some pinball places out, they used some of it on nearly every pin, to either ground the backbox or to ground bulbs and things under the playfield.
As long as you use heavy gauge stranded wire, it's fine. The advantage to the braid is that it flexes far better than any wire can do, so when it gets moved over and over, it doesn't break.
