OK... I have a Turbo Outrun that has a ground line running from the monitor frame to the metal backplate on the door which has the PCB on it (which, in turn also has a ground wire running from it to other things, etc.).
Anyway, while the ground wire it attached from the frame to the backplate, I get static on screen... nothing huge but it's noticeable to the point I thought he monitor needed to be re-capped. Once I remove the ground wire from the frame to the back plate, it clears right up and looks awesome.
SO...
To what detriment would it be to simply leave the wire disconnected?
What options do I have?
Thanks!
SO...
Thanks!
