Stargate thrust sound wont stop while advancing waves...
Thomas
Donor 2021
Virginia
When I clear a wave and move on to the next the thrust sound keeps on going. Any ideas on this guys?
Is this the same Stargate that you mentioned earlier having different sounds?
If so, check that the sound board and its ROMs are correct. I had a similar problem (incorrect sounds and long thruster/fire sounds) on my Stargate mini and it turned out to have a sound board that was jumpered for Joust w/ Joust ROMs in it.
- Mike
Yea its Stargate #2 I just got it up and running. So I started a new thread on this issue because the other was solved. Anyway I did mention strange sounds in the other thread. I went back and played it again and that is the only strange noise that seems out of place atm.
How would I go about checking what you have suggested above?
I went back and played another game and once you touch the thrust it never stops unless your killed. Now it is not the full on thrust that you hear when going full speed but the lower pitched one like if you were just tapping the thrust.
I can only assume your talking about board Id thru robotron 2084 or something?
http://www.robotron-2084.co.uk/techwilliamshardwareid.html#stargate
Yep I was just checking that out... Thanks for the tip I will need to id them and go from there.
Well I got home tonight and fired up the stargate. I have no sound at all now. Bummer...
We pulled the board and cleaned the pins with scotch brite then checked the fuses. Put the board back in and still nothing. I checked thru my pile-o-boards and thought I had some others. Nope so there wont be no R&R on it.
So what do you suggest? It was working fine this morning except the thrust issue...
