shopboyroy New member Joined Aug 1, 2008 Messages 1,057 Reaction score 1 Location Chattanooga, Tennessee Jul 4, 2009 #1 Stargate has blank orange screen. Also flashing 1 & 3 on the board, any ideas?
modessitt Volunteer: Encyclopedia Submission Moderator VAPS Joined Mar 22, 2007 Messages 33,414 Reaction score 325 Location Austin, Texas Jul 4, 2009 #2 If you have another CPU, try swapping it out. Are all your LEDs lit on your power supply?
saltbreez Member VAPS Joined Jul 4, 2008 Messages 878 Reaction score 3 Location Olympia, Washington Jul 4, 2009 #3 shopboyroy said: Stargate has blank orange screen. Also flashing 1 & 3 on the board, any ideas? Click to expand... Start by checking voltage potential at the RAM chips corners. [Assuming no issue here] Next, as has been suggested, board swap to isolate the problem to the MPU or ROM board. What comes next depends on what you have found in these steps. Saltbreez
Michael Roma Active member VAPS Joined May 17, 2008 Messages 1,404 Reaction score 18 Location Woodbridge, Virginia Jul 5, 2009 #4 Here is what you should be looking at for voltages at the RAM chips... Also, pull the connector at 1J3 on the CPU board and test voltages there to see if there is any drop from the connector to the RAMs. If the voltages are low (especially the +5v) I would reflow the solder on the header pins 4J1, 4J2 and 4J3 (power supply board) and 1J3 (CPU board). - Mike Last edited: Jul 5, 2009
OP OP shopboyroy New member Joined Aug 1, 2008 Messages 1,057 Reaction score 1 Location Chattanooga, Tennessee Jul 5, 2009 #5 Thanks, I'll let you know what I find.
OP OP shopboyroy New member Joined Aug 1, 2008 Messages 1,057 Reaction score 1 Location Chattanooga, Tennessee Jul 5, 2009 #6 Mmm........Screen went blank.............Smell kind of smokey 'round here.....Mmm.
