stargate fl light
tester007
Calgary, Alberta, Canada
Been meaning to get to this for a while but haven't.... the marquee light seems to be some odd length like 14" and I have never been able to find one. Anyone know of any box store that might have that length or online?
Cool.. thanks.. its one of those things I have been meaning to do for a couple years.. every store I go into and it comes to mind don't have anything close. Odd they would have used such a unique length... there is lots of room for a more standard one.
The F14T12 is the exact bulb that you are looking for.
If you cannot find one, you could always unscrew one end of the bulb holder, drill a new hole, and move it over 1 inch. You then can use the more common 15" bulbs. The existing starter will also work with a 15" bulb as well.
-MUEL
-MUEL
This is the most common fix, if you don't replace the whole unit from your local home imporvement store for $9.
I bought a whole new unit, then thought why not keep it original, then thought of moving the ends apart.. then forgot.. lol.. I'll try and order one and get the marquee back on after a couple years without.
