Stargate: Cant understand the schematics manual!
JohnB
Cherry Hill, New Jersey
Hello guys, I am working on fixing up my Stargate pinball and my glider motor is shy and the glider toy doesnt come forward to play. It does however still move left and right inside its housing. The Glider Stop Motor switch is also reporting failure so I am replacing that. Perhaps that staying open is what caused the issue with it not coming forward now. Anyhow, I cant make any sense of the schematic in the manual in reference to forward glider motor. Its on page 55-56 can anyone help me translate Premier/Gottlieb Goa'uld?
If the switch isnt working, that is most likely your issue. But just for kicks, check the switch report, I had a simlar problem, turned out 4 other switches wouldnt register, found a wire off of one of the switches on the column down lower, fixed. GTB used organic solder, which is more prone to this type of failure..
