Ok so where to begin,.. First this stargate looked to be hacked to pieces,.. It is in a defender cabinet, on a sinistar board, looked like defender Io board, and running stargate. I do not know, but apparently it worked flawlessly at some point.
So the guy I am helping out had a tech who did some work for him but was let go and so I sort of came into this mid way through so to speak. Thrust is always stuck on right now. The old tech and I then both tracked it down the middle IC chip in the IO board. The chip is now obsolete, so I picked up a new CD4049UBEX chip, put in a new socket (thankfully) and the chip in the socket. I also reflowed the socket pins as they looked to have some cold joints starting to form.
Turned that puppy on and OMG the ship was not stuck on thrust. It worked great and was playable. Went through a game, went through another game and as soon as the third game started ,... The thrust was stuck on again. I reseated the chip and turned it off and on and stick stuck on thrust. I smelled around the IC board and had a slight electric smell but nothing like a shorting power supply or the like. Just mild smell. I am not sure. I have one more CD4049UBEX I can try in there but have a feeling after 5 mins I will be back to a stuck thrust.
Looking back I should have went off my check list and checked the power supply first. Out side of that I am not too sure what else to do or try. I did pick up a stargate board from e bay and that did nothing. I thought it was a stargate board not a sinistar if that makes any difference. I changed the cap on the IO board. Any other suggestions I would be all ears.
