I've got my Star Wars Trilogy machine finally put back together and have the game running. Right now I cannot aim to the left or right...only up and down. In test mode the calibration isn't show any activity on the left to right direction. The panel has apparently had a problem with left/right movement before I got it so I'm hoping it's a simple fix. I checked out the wiring and didn't see anything wrong. I tried swapping that little amp pcb and it made no difference either. I even tested the pot and was able to see it change its range of values when using my meter. The only odd thing is I can't get either pot to show the full value when checking between both outside terminals. Since one pot is working I'm not horribly concerned about that reading. Anyway, the last thing I noticed was that the 2 outside wires (one red and one black) were switched around on the non-functioning pot compared to the working one. A real simple question, but does it matter which outside terminal those wires go to?
