Star Wars Trilogy DLX Questions
RedWarrior80
Erie, Pennsylvania
Hello All,
My quest to find this game is complete!!!--sort of.
Found one in decent shape, defiantly needs a good cleaning but all the parts are there and force feedback works. My questions are as follows:
1. The joystick seems like it could use some love: Where (if anywhere) can I buy replacement springs/parts? Also should I replace the pots?---if so what type of pots does it take?
2. The force feedback, when is it suppose to work?? ie. If I'm on hoth flying around, if I make a quick turn should I feel the feedback? I defiantly do feel it when I get hit.
3. Anyone know the type of bulb the control panel lights take?
For those wondering my plan is to gut the toshiba projection monitor and replace with an extra 42" plasma I have. I would be certainly open to parting out any parts of the monitor that may be of interest to somebody.
One more thing.....I have a grey phone line looking wire....could that have been from a Swipe Card System??? or does that actually go to something on the game?
I have 2 different versions in my 2nd job arcade. The small deluxe with FF and large deluxe w/o FF. On the small deluxe, the control panel uses the standard house light twist in bulbs. Maybe 25 watt frosted.
I don't think the large used any bulbs. (It's been a while since I had it opened.)
You will need to use the higher end Gnobes video adapter card. Here is a video that shows you how to set it up:
I did this to my large SWT, my small SWT already was set-up with this(my display is going out on this one, works after being on for about an hour, just thick black bands going up/down).
Thanks appreciate it. Do you have a link or recommend what Gnobes adapter I know there is a lot of knock offs out there. Thanks
