Star Wars Racer - Hitachi Monitor Failure
Didj
Wake Forest, North Carolina
Hello,
I have a Star Wars Racer unit (not the deluxe), model STD-POD-GPI with:
CRT: Hitachi
Type: A78LCU30x
Chassis has the part number 025 1486-001
The problem is that the monitor is completely dead. I cant see any glow or signs of life. I have reseated the neck board, checked power etc, but nothing is jumping out as a failure.
Are there any resources I can study on this particular monitor type? Searching the forum did not yield much for this particular model. Trying to find a place to start on the debug.
Thanks,
Didj
Hello,
I took the following pictures of the chassis. Also, while I was in there I noticed the power supply transformer looks like it might have gone bad. But, you were right on checking the chassis. Turns out its a 85x0414-001D.
Here's what I was able to find out after you're suggestion
MODEL: WGM3332-U0TS65G
DESCRIPTION: 33" U3000 VGA UNIV
CHASSIS: 054A3301-001
NKBRD: 054A0583-002
CRT WG P/N: 088X0392-506
Power Supply Board with the transformer that looks suspicious
PCB Number: P756 POWER SUPPLY
Model # 33K3301
Monitor Part # WGM3332-U0TS65G
Monitor Replacement: None Mentioned
Comments (Replacement): None Provided
Searching for a schematic now as well.
Suggestions welcome and opinions on the power supply transformer.
Didj
Wells Gardner U3000, it's one of the few WG's I've never worked on so can't help you a lot. Isolate the b+ and work from there if it's anything like a u2000 or u5000 :D
Hello,
NKBRD: 054A0583-002
Model # 33K3301
Didj
You shouldn't need a schematic.
keep it simple, caps connection and if tube is good then a flyback
if all you need is caps, looks like the fly has a crack in it by the pots.
it won't kill the chassis with just a crack ut will mess with
the focus and screen brightness.
Carefull removing the pin amp transistor
by the power supply, easy to brake a leg.
measure the dc at the ps connector before you replace all the e-caps
except for the filter cap. compare the dc before and after, most cases the B+
doesn't need adjusting.
easy to cap chassis.
wells has the manual.
Thanks, I finally had some time to test some voltages based on the pointers. I would have bet the power supply board was bad, but I measured at the chassis and I am getting
Red to ground: 22.7 VDC
Orange to ground: 180.4 VDC
I am taking this to mean the power supply board is delivering enough voltage to the chassis, so now I am looking at the chassis.
I'll examine the flyback, but as you said, it shouldn't kill the monitor, and I am getting zero out of the monitor and no neck glow.
Any things to zero in on given the complete lack of response from the monitor?
Thanks,
Didj
Thanks,
Didj
B+ is to high.
Do you have that much on the collector of the HOT.
need your 22v to 12 zener z700 cathode voltage for the HV ic
with no drive from ic the B+ will max out dc from no load.
or your in shutdown that's where the ic has shut off the osc
and no drive from pin 12.
wells have a voltage chart..
If you put the bulb on the B+ from the PS then it will drop the dc
so the chassis can start up.
Any burned up or faded color bands on the resistors?
can be a clue theres a part over heated it.
any holes in the flyback side of fly.
If original caps then should replace them what a 1998 chassis
but you can check around for anything obviously bad.
Heater comes from the fly so no hv then no heater.
