Star wars question-turned picture
solo742
Colorado
Picked up my SW today (finally) and the picture is turned slightly off center (if you saw it it would be easier to explain)
Anyway, I was told you sometimes can rotate the yoke (gently) to corrent this in raster games, and I did not know if there was something else or if this was possible for an XY game as well.
Thanks,
Jim
Solo742
I would rebuild it with a cap kit and do the upgrades to the monitor first, if it hasn't already been done. Then you can make the necessary adjustments to the monitor. Add pics if you are still having problems.
Thanks,
Jim
Solo742
Yes, you can do that. Loosen the yoke screw and carefully and slowly rotate the yoke. If it doesn't move, it probably wan't loose in the first place and perhaps your issue IS with your chassis.
