Star Wars Power Supply Missing AC Plug
OU Flight
Spring, Texas
I have been trying to figure out why my marquee wasn't working. After replacing the bulb, ballast, and starter I discovered that the AC line running up to the marquee isn't plugged into the power supply. On top of that there is nothing to plug it into. The second AC plug J4B is missing. I checked it against my other Star Wars power supply which is correct, and this one looks like it was just never wired for the second plug. Any reason why? Also where is the best place to get the plug socket and a new terminal block that has the correct 4 line out instead of 2?
I have the same issue as my block is from a Space Duel. You don't need to replace the terminal block if you can find piggyback spade connectors like the one below. I think Bob Roberts has the plug we need:
