Star Wars Pod Racer conflicting seat problem
FlashbaxArcade
Burleson, Texas
ok im getting a "conflicting seat 1" on a linked twin pod racer sitdowns i just received and don't know how to fix this. probably an easy fix! i believe i hooked everything back up correctly though.
it comes up, booting, and networks with each other. left machine says Node 1/1 and the rt screen shows Node 1/2 so i would think that that is correct! however, further in booting, it will say they are different "nodes" but same "conflicting seat 1" on both. i looked in manual on "JVS test" and both say 1/1. i went into "system assignments" and left says master and rt is slave(which i would think is right).
how do i correct the seat conflict?
what do i set the number of players also since i have twins(2 linked)? "2" on both?
thanks for any help as i do not usually work on these drivers....
I would think that seat one should say Node 1/2, and seat two should say Node 2/2...purely a guess though.
