Star Wars PCB Test Rig (Laid out flat)
dezbaz
Donor 4 years: 2011, 2013-2014, 2016
Ballajura, Western Australia, Australia
My Star wars PCB is playing up, so I need that working to do other projects. (IE: Amplifone Deflection)
This is the solution I designed recently. Got some PCBs back from the board makers today
The pic shows a re-configured Interconnect board. A flat version, so the boards can be tested in an opened out position as opposed to back to back like they are normally
I had to source some 86/43 way (2.54mm) edge connectors, I got some of them off eBay, so I look forward to rigging something up soon (these get soldered to the finger area)
I have the 30 Way and 44 Way Edge connectors (3.96mm) ready to make a test harness, which replaces the filter board side (the 30 and 44 way edge connectors get soldered to a harness), then onto a 30 and a 44 way fingerboard
I will take a pic of the test rig once the harness is made
This looks great, I could sure use something like this, about to embark on some SW repairs myself for the first time.
No probs
You will need 3 of these (2.54mm)
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=260863374195
Also get 1 x 15/30 Edge connector (3.96mm) and 1 x 22/44 Edge connector (3.96mm)
Try to get the eyelets, as they are easy to solder wires to
I have my 3 x 43/86's on the way, so I would like to assemble the proto prior to offering these for sale. I had 10 pcbs made so there are extras
The connectors arrived today from the US
6 days Using DHL, mind you it cost a LOT for DHL :eek:
This is the PCB Below idea, in case it wasn't clear :)
A third connector (Optional) can be soldered to the holes in the centre if you want to test the sound board too
I just need to solder the tags to the board
Nice. What's the approximate cost of putting one of those together?
Darren Harris
Staten Island, New York.
Hi Darren
The connectors are on eBay for about $7.75+ each (23.35 + 3.85 freight = $27.20)
The bare board will sell for about $20 (KLOV Price) plus freight. Likely Freight will be $7.50 or so ($27.50)
If you make a harness for the 44 and 30 pin connectors, all that gear is cheaper and common, maybe add another $10.00 to make up the kit
$64.70 Approx, ready to plug into your SW Harness
This is not a for sale thread, so all that will be finalized when the first one is made this weekend.
Guess what?
Pin 2 on the Star Wars Filter board (Harness side, 22/44 row) is not connected to anything
Not sure why, it connects using a track at the PCB end, just not the harness end :confused:
